Enables the transmission of LLDP SNMP trap notifications.
all | Specifies all ports on the switch. |
port_list | Specifies one or more ports or slots and ports. |
Disabled.
To enable SNMP traps for LLDP MED TLVs, you must issue a separate command; use the enable snmp traps lldp-med {ports [all | port_list]} .
If you do not specify any ports, the system sends LLDP traps for all ports.
The Avaya-Extreme proprietary TLVs do not send traps.
The following command enables LLDP SNMP traps for all ports:
enable snmp traps lldp ports all
